New and having some issues.
  • pyrobee
    • Jun 2012
    • 68
    Alright I am a noob, but I have an issue and would like to get it fixed before I get into modifying my car. I have a European spec 87 318i. It was running great and now it surges and sometimes has very little power until I get on it, and when I slow down(and I downshift when doing so) the car will intermittently cut out. I am thinking the MAF or Idle Control. Any ideas? also my fan is running constantly...I am thinking relay. Thanks for all of the Help! I look forward to my build and looking at everyone else's beauties.
  • thebutterson
    • 463
    does it have an m10 or m40? If it's an m40 you may have better luck in the m42 forum section.
    • Hey_You
      • Nov 2009
      • 963
      Either way, double check all your grounds!!! (If it's an m10, the ground on the intake manifold). Also check to make sure your starter reference wire (the small wire going to the starter) is snug. That can cause issues. Also, if it's an m10 (or has 2 fuel pumps), make sure they are up to spec.
      85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
      • pyrobee
        • Jun 2012
        • 68
        Its an M10 that is why I posted in the M10 section. I recently did a tune up and it was running rough but it was running okay. I have gone through all of the vacuum lines the fuel rail pressure and the injectors. All is good, and The spark and plugs are all gapped right and creating plenty of spark. the only way to get it to run properly is adjust the screw on top of the manifold which I am figuring is the fuel air mixture screw. I am new to these cars so I am just doing what my mechanic training has taught me. I am thinking it could be the ICV or the MAF so I am planning on deleting the ICV and doing some more troubleshooting
        • Hey_You
          • Nov 2009
          • 963
          Coolant temp sensor can cause a bunch of issues, and it's pretty cheap to replace.
          • pyrobee
            • Jun 2012
            • 68
            I am going to order the Temp sensor and probably a new cold start injector or I might just clean out the injector. I have not really had the time to take it off and look at it.
