Snapped a key in ignition help!
  • E30_Pare
    • 7801
    So a key snapped in my ignition. Like I guys should know the cylinder doesn't have the little slot to release the barrel. How can I get it out? I tried picking it. No go
    DREWLIENTE
    1$ PShops PM me
  • dr.strangelove
    • Jan 2005
    • 847
    im pretty sure you already tried this, but can you turn the key in the ignition cylinder with the handle along with the blade in there?
    If you can, you can use the paper clip trick to remove the cylinder.
    If all else fails, I was a locksmith at one point and we used to use a tool to fish blades out of cylinders. Maybe ask at a shop to see if they will sell you one.
    heres an image of what I'm talking about
    the bottom ones.
    Good luck!
    I'm sure someone can chime in on cylinder removal assuming you can turn the key.
    • Mr. Schwarz
      • Nov 2011
      • 153
      Im in the same spot, its been chilling there for almost 10 months now. lol.
      • E30_Pare
        • 7801
        I can turn the key, but like I said in the first post I can't remove the cylinder like later cars. I'm stuck in a rut. Can't really get a paper clip in between the key. Thinking abou just pulling the shaft so it's easier to work on.
        DREWLIENTE
        1$ PShops PM me
        • jeffnhiscars
          • Jun 2011
          • 6011
          If you can turn it then you can remove the steering wheel at which point I think you should be able to remove the entire lock mechanism and either replace it or take it to a locksmith for service.
          Alice the Time Capsule
          • E30_Pare
            • 7801
            Yea I think il just have to pull the steering column & take it to a lock smith. How much does something like this usually cost?
            DREWLIENTE
            1$ PShops PM me
            • jeffnhiscars
              • Jun 2011
              • 6011
              Make a couple of calls or stop by a local locksmith and look humble...lol
              It might be cheaper and/or easier to buy a new lock unless they can duplicate whats left in your lock. Just remember that if the lock jams and you cant unlock and remove the steering wheel, you are f^#ked.
              • E30_Pare
                • 7801
                Haha I guess il have to try that. Really pissed though cause my pops was the one that snapped it. After I told him to be careful NOT to snap it. Last time my friend snapped my key in the door. 40miles from a spare. Fml. The key copies r garbage I need to drop money at the dealer.
                DREWLIENTE
                1$ PShops PM me
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Not only is that the right way to go, but if you are not in a desperate time crunch, have them order you a lock with your VIN...so you dont have to change any other locks ;)
                  • E30_Pare
                    • 7801
                    Seems pricey D;
                    DREWLIENTE
                    1$ PShops PM me
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Seems pricey D;
                      When you find out what, if any price difference there is between a new lock with a generic key vs one keyed to your VIN, let us know.
                      We are all eager to hear the results of your research, Your Overlordness
                      • E30_Pare
                        • 7801
                        When I have time to do work il lets you guys know. Gunna try a few more things before I bite the bullet & go to a locksmith
                        DREWLIENTE
                        1$ PShops PM me
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          STEERING / STEERING / STEERING COLUMN & WHEEL / Cyl & keys
                          Cyl & keys 1984-89
                          MSRP Core ? Save Online Price
                          $39.70 $0.00 $7.94 $31.76
                          I dont know why Im so nice :bow:
                          • E30_Pare
                            • 7801
                            Lol nice thanks bro
                            DREWLIENTE
                            1$ PShops PM me
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              Coded locks
                              http://www.realoem.com/bmw/showparts...54&hg=32&fg=30
                              I get a price of $43 but it says NLA so it would require a phone call to a dealer
