I made sute my plugs are in the right order. Hey i just remembered when i went to put the new plugs in that they wouldnt fit into the wires all the way, so i had to take the little aluminium nipples off of them.. they kinda just sit loosley in there holes.
Help me fix my M10?
sounds like timing is off...
i had similar issues as adding throttle and the car wont get passed a certain RPM.
check the timing.
you can check the valve clearance. thats an easy do.2007 Mazda CX-7 (red TURBO!!)
1985 BMW 318i.... beige!
2007 Suzuki GSX-R 600 (red)
previous cars
1) 1994 Isuzu Trooper (blue)
2) 2005 Scion tC (panda w/ CF)
3) 2001 Toyota Avalon (silver)
4) 1988 Nissan Pulsar XE (T top in red)Comment
Some terms that get thrown around here a lot that you might find useful. Feel free to add some guys.
CTS: Coolant temp sensor
AFM: air flow meter (not the same as a MAF on these early BMW's)
TTS: temperature time switch
TPS: throttle position sensor
ECU/ECM: engine control unit/module
ICU: Ignition control unit
ICV: idle control valve
TB: throttle body
DIZZY: distributor
CAT: catalytic converterComment
