Ok, So lately my car has been overheating. I touched the top radiator hose and it was hot and the lower hose was cold. I replaced the thermostat. I then noticed that It is leaking coolant from somewhere and it was getting on the belt and splashing everywhere. So then I changed the lower radiator hose and the "water pump to thermostat" hose along with new clamps. Now I know the hoses are not leaking for sure. But there is still a small leak somewhere close to the belt that goes to the alternator cause thats where I see most of the antifreeze. My next thought is the water pump? How do you know if its bad? Also The top hose is still hot and the lower hose is still cold. Can it also be the new Thermostat isnt even good? Any help would be great.
Overheating
