Fuel lines?
  • boostless
    • May 2013
    • 66
    Fuel lines?
    I'm going through my car looking at vacuum lines and noticed the fuel lines are cracking as well. Can I just go get the basic fuel line from a local parts store and call it good? I was under the impression that it shouldn't be used in fuel injection applications due to the higher pressure.
  • Ian Bowers
    • Apr 2008
    • 1120
    You can get high-pressure rubber fuel injection lines from an autoparts store.
    • Swanny
      • Mar 2012
      • 2834
      They sell high pressure hose. If you're doing all the lines i suggest getting a reel from blunttech.
      Swanny!
      SUCKERS.
      • boostless
        • May 2013
        • 66
        I guess I'll be picking some up tomorrow then, thanks.
        • jeffnhiscars
          • Jun 2011
          • 6010
          You should use FI rated hose for all fuel lines since non FI hose does not tolerate ethanol. You can usually get 5/16 FI hose from Napa which will work although the correct size is 8mmx11mm. I paid $32 for a 5m spool which will do both lines in the engine compt on 2.5 cars. Works out really well if you have .5 car laying around :-)
          Alice the Time Capsule
