Blocking removing a coolant hose?
  • boostless
    • May 2013
    • 66
    Has anyone blocked/removed the hose that comes off the front of the engine down to the thermostat? It seems like that just recirculates the hot coolant back through the engine which would help warm up faster but not help when the engine is actually hot.
  • TobyB
    • 5263
    Keep the stock system. It has worked well for 40 years, and was an improvement
    on the original 1500 system that did exactly what you describe.
    The 'modern' system does a better job of keeping the engine at a constant temperature.
    t
    • boostless
      • May 2013
      • 66
      So I'm looking at my water pump and it looks as if the "fan blades" are spinning the wrong way on the water pump assuming it's spinning clockwise. I want to make sure that my belts are routed the right way but I can't find the belt routing diagram. I don't see how I could have it routed wrong but I would like to make sure.
      • Todd Black 88
        • Oct 2007
        • 3449
        Remember... You "sling" water off the blades, and "scoop" air with blades.
        Originally posted by codyep3
        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
        2001 silver/Blk 325 cabby. SOLD
        2002 325xit Sil/blk. SOLD
        2010 F650gs twin
        • Tzzantaru
          • Jul 2013
          • 21
          Any way you routed the belt (and I'm not sure that you can route it wrong , even if you wanted to) it is still governed by the crankshaft so it's pretty impossible for the belt or the water pump to spin in the "wrong" direction.
          And , yes , the normal roation of the engine is clockwise , if you look at the engine from the front.
          • boostless
            • May 2013
            • 66
            So the correct spin direction for the water pump should be clockwise as well then? I just want to be sure.
            • Tzzantaru
              • Jul 2013
              • 21
              Yes , the correct spin direction should be clockwise.
