Need M10 pistons
  • Smelser
    • Feb 2011
    • 633
    Need M10 pistons
    I am searching for pistons for my M10 race car.
    I am getting most of the stuff from Ireland and rock auto.
    Had anybody found pistons cheaper then the 500-600 range for four that I have seen?
    sigpic1984 318i Total conversion to a DIRT race car.
    Check out our build on facebook @ www.facebook.com/brewstermotorsports
  • boostless
    • May 2013
    • 66
    Are you looking for stock stuff or "performance" pistons?
    • Smelser
      • Feb 2011
      • 633
      The rules at ohsweken speedway don't really say much.
      Basically anything that gets run hard from 4-6500 rpm range. Second gear only. Slight lift on the pedal and back down hard. Using stock replacement cam. Thinking around 9.5 10 or 10.5 comp ratio.
      • kronus
        • Apr 2008
        • 13032
        I have some lightly-used forged JE 92mm piano tops sitting around that I likely won't use, as I don't have an M10 anymore. The problem is I don't know the CR they're intended for. They came from a turbo engine that blew within 50 miles, so maybe they're higher-comp than their previous owner thought.
        cars beep boop
        • Smelser
          • Feb 2011
          • 633
          Tech guy said stock or stock replacement. Are the stock ones cast or forge?
          • SkiFree
            • Jun 2011
            • 2766
            cast ... and I owe you an email. Sorry.
            ADAMS Autosport
            • Smelser
              • Feb 2011
              • 633
              Lol. No rush yet. Actually if you Jer or Jeff could call one night. I wanna discuss my engine farther. Get my total set up. Planning on a January purchase. Also wanna talk carrying the IE logo. I mentioned it to Jeff when I got my bushings the other year. He laughed and said let's see how you do on the track first.
              I also never thought of something. If I bore out my engine to the next size oversized. Does that change the head gasket I will be to use.
              Talk to you guys soon
              • Smelser
                • Feb 2011
                • 633
                Also. YouTube search battle with chad Smelser.
                It's a helmet can view of Lucas Lubin. The driver if a neon. I am the yellow car battling with him. It's interesting to watch. Knowing my engine is 30 years old and tired as hell. These BMWs handle like a dream. !!
                • TobyB
                  • 5280
                  MaxSil are a bit cheaper- but the reviews are mixed.
                  t
                  • cm0180
                    • Apr 2012
                    • 56
                    I have those, if you're interested
                    • TobyB
                      • 5280
                      that would be a good way to go, especially if you can use the domes in a standard bore block-
                      'stock appearing' for the win!
                      t
