M10 boost threshold
  • Deadskittles
    • Jul 2011
    • 140
    M10 boost threshold
    Hmm... Ive been brooding over my next build and a tantalizing idea would be an m10 with some serious boost. I guess a question of mine would be what is the max a built m10 could handle? 30-40 pounds?
  • travish325
    • Jun 2012
    • 1151
    Who knows. There's a lot of variables.
    • Todd Black 88
      • Oct 2007
      • 3449
      Well, BMW used the M10 block in formula 1 in the early 80's, to produce between 1300-1500 hp in qualifying trim. They ran 50-60psi of boost. They didn't last long at that level, but I would think 25-30psi would be doable with proper assembly and tuning.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • Deadskittles
        • Jul 2011
        • 140
        I believe in the qualifying trim it was closer to 80 pounds. Sources suggest 5.5 bar (multiplied by 14.69 psi) = ~80# of boost. Im just curious what people have maxed the blocks at. With H beams and forged pistons and a 2002 crank im curious if 40# of boost is achievable.
        • HaloArchive
          • Sep 2011
          • 135
          The M12/M13 was capped at 1500cc, so much smaller than the m10. Which allowed for that amount of boost before block cracking. IMHO, a 1800cc M10b18 built up could probably handle 800WHP with a large turbo and ALS in place. It would not be very street friendly though without ALS.
          • Deadskittles
            • Jul 2011
            • 140
            Interesting. Could there being a built valvetrain help? (high redline 9000-10000?)
            Also, ive heard ALS can decrease the life of turbos, is this true? and how dramatically?
            • LJ851
              • 7919
              Lorin
              The M30 is God's engine.
              • E30_Pare
                • 7801
                Good&Tight was running somewhere around 30psi.
                If i remember correctly was pushing almost 400hp. Not sure if with nitrous though.
                DREWLIENTE
                1$ PShops PM me
                • Jaxx_
                  • Dec 2009
                  • 1880
                  367(?) whp on the dyno before it blew up.
                  There are a lot of variables with turbo tuning. Usually a full valvetrain is not something that "goes" when it comes to turbo motor failure. Things to worry about most are bottom end related. head studs, cooked pistons, bent rods, or even cracked sleeves. Don't get me wrong, valve train is important too, but you'll get more bang for your buck throwing in some forged rods and pistons than getting rocker arms that are designed to rev to the moon.
                  • TobyB
                    • 5263
                    It can hold as much as you can throw at it- dollars, that is.
                    2 liter forged fully- counterweighted crank, hemi'ed head, custom pistons, long rods
                    an earlier thicker 2l block from a 2002, that setup can take a lot of combustion pressure.
                    So you could then run a significant amount of forced induction.
                    If you ran a conservative cam and low static compression, yeah, sure, 2 bar.
                    You might make more POWER, though, with less boost and a more aggressive
                    compression and cam.
                    It's all just money. And some time.
                    t
                    • E30_Pare
                      • 7801
                      Would it be better to keep stock bore and add more boost? Than to sacrifice integrity going with 90-92mm bore?
                      DREWLIENTE
                      1$ PShops PM me
                      • Deadskittles
                        • Jul 2011
                        • 140
                        It probably depends on where the weakest point in the motor is. If you had a forged crank,rods,and pistons plus ARP, and MLS, i would assume the next weakest thing would be the bore? In other words if you are not running all that forged good stuff you wont be needing to worry about the bore because that probably wouldn't give out first. However for max boost with all the upgrades that would be the main concern, i.e. keeping stock bore would be the safest. Thats just my thoughts.
