best aftermarket clutch kit for 85 318i
  • e30sky
    • Aug 2013
    • 106
    hey guys what is a good aftermarket clutch kit to go with the m10b18 set up in a 85 318i
  • Jaxx_
    • Dec 2009
    • 1880
    I have a spec stage 3 clutch. It's quite grabby... probably on the edge of streetable.
    • jaywood
      • Jul 2010
      • 4528
      Just go with an OEM clutch
      • Holland
        • Nov 2008
        • 7212
        100 gerbils of fury will be too troubled to fry one.
        Originally posted by DEV0 E30
        • thebutterson
          • 463
          the extra money is better spent lightening the flywheel if you ask me. Do you have plans to add a significant amount of power?
          • e30sky
            • Aug 2013
            • 106
            not really?
            to be honest, i just want the car to be driveable for now untill i swap out the m10 for a m20. but at the same time i might play around a bit with the m10 to get a little bit more out of it. so yeah i will be increasing the horsepower
            • e30sky
              • Aug 2013
              • 106
              cost?
              what is the cost for the complete kit?
              • Jaxx_
                • Dec 2009
                • 1880
                I think I found it for $340USD about 2 years ago. Look around and you can find it for less than the MSRP of $369.
                It's rated for 290ft lbs of torque.
                • SkiFree
                  • Jun 2011
                  • 2766
                  This x1000, you have absolutely no reason to "over clutch" your setup. The oem setup is fine, and as also mentioned your time (and $) would be much better spent lightening the flywheel.
                  If you want something a little more grabby, just use the pressure plate from an E30 M3 as they are a good %30-ish stiffer. This is what we run on the 2002 full race cars that are pushing a good 160-175ish at the wheels (albeit we do run 6-puck solid hub disks which wouldn't be fun for street use).
                  ADAMS Autosport
                  • e30sky
                    • Aug 2013
                    • 106
                    thanks
                    hey thanks alot
                    • e30sky
                      • Aug 2013
                      • 106
                      thanks
                      hey thanks alot, but you see my problem is we dont have much e30's here in Guyana, and i currently dont have a brand new oem clutch kit for the m10, well i do but its wise to not reuse old stuff. what i wanted to know is where can i pick up a complete oem kit brand new for the m10, also why i turned to aftermarket kits was that you can easily find them out there........i think lol
                      • TobyB
                        • 5297
                        Little known secret-
                        the E30 M20 pressure plate and friction disc work with the M10.
                        You DO have to source an earlier 2002 228mm flywheel, though, which might kill it for you.
                        But then, if you went M20, you already have your clutch.
                        Sadly, the M10 flywheel is different than the M20- or you could do a whole kit...
                        t
