BMW M10 performance clutch options..
  • PeturW
    • 24
    Hi.
    It seems that options for a performance clutch for the M10 are very limited.
    This is the only option I have seen, the site hasn't got much info.
    I'm bolting this to M30B30. Were I live gearbox options are VERY limited. So M30 gearbox is out of the question.
    If you have any info, please share.
    Greetings from Iceland.
    Peter Wilhelm J.
    Diamond schwarz, BMW E28 518i - M30 swap in progress
    Schwarz Mica, 1994 BMW 325i Touring - M50B25 Vanos - 3.73 LSD - Design Edition.
    Brilliantrot, 1989 BMW 325i Touring - M50B25NV - Drifter - Welded diff, sold
    Alpinewiess II, BMW 318i - M10 - euro pre-face, sold
  • thebutterson
    • 463
    Some people use the pressure plate from an e30 M3.
    • Deadskittles
      • Jul 2011
      • 140
      • TobyB
        • 5297
        Hmmm. If you have the M30, it should already have the 228mm flywheel, I think?
        If not, you can get a 228mm flywheel off an early 2002, and use an E30 performance
        clutch disc and cover. That gives you a lot more options...
        hth
        t
        • marshallnoise
          • Sep 2013
          • 3148
          hth
          t
          That's the way to go. Sourcing a 2002tii or ti flywheel is a pain though. At least used...
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • TobyB
            • 5297
            It doesn't have to be a tii, just early production. I think it changed sometime in 73 for the flywheel- after 12 fuse, aroundabout square taillights...
            t
