Bmw m10 284 schrick cam help
  • Gklock15
    • Feb 2015
    • 58
    I put a 284 schrick cam in my m10 and when I started it it had no power? Any ideas?
  • LowR3V'in
    • 4209
    Get off the computer and check out of you put it in wrong or if anything is disconnected or broken. Perhaps it lost timing.
    • LJ851
      • 7919
      Is your distributor spinning the correct direction?
      Lorin
      The M30 is God's engine.
      • Gklock15
        • Feb 2015
        • 58
        It's started before and I could drive it just had no power
        • thebutterson
          • 463
          Here's some info you should provide:
          What year/car your m10 is in
          What car the cam you bought was advertised for
          Things you have checked since you posted this
          Your timing settings
          Other modifications to the engine
          Without anymore info I would say to verify the cam is timed correctly by verifying the line on the cam lines up with the boss on the head at #1 TDC, then check your timing, and verify all components are connected and properly installed.
          • Gklock15
            • Feb 2015
            • 58
            It's a 1985 bmw 318i we have rotated the distributer and it's spinning the right way my guess is maybe the timing marks aren't lined up right or is it possibly while running it out if time it jumped time? But I do know that it's out of time because it's backfiring through the intake
            • LJ851
              • 7919
              What do you mean by this ? Does the distributor rotate the same direction as the arrow on the outside of the distributor?
              Lorin
              • Gklock15
                • Feb 2015
                • 58
                how can I adjust my ignition for the bigger cam
                • Good & Tight
                  • Apr 2004
                  • 2057
                  First check the spark plugs wires are in the correct firing order.
                  Check for vacuum leaks, rocker arms properly adjusted .008 while warm.
                  Then verify timing is correct with a timing light. That can be checked in two places, front crank pulley and also through the bellhousing on top of the transmission.
                  You can adjust the timing by turning the distributor. You will need a timing light while doing this to check advance.
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • solo318
                    • Jun 2012
                    • 183
                    Make sure your cam was designed for a late m10. The early m10 engines spun the distributer the other way That would make your 1342 firing order 1243 and would fire 2 of the cylinders out the intake.
                    • Gklock15
                      • Feb 2015
                      • 58
                      It's spinning the right way? But it might be that my chain is off a tooth or something because we checked the motor at tdc and the mark on the pulley didn't line up right so is that possie
                      • barry
                        • 1642
                        Your better off googling your situation for best information
                        • thebutterson
                          • 463
                          Here's some photos I made, maybe they'll help
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            I would add to make sure #1 is at TDC on the compression stroke (ie both valves closed) when you install the distributor. Otherwise you'll be out 180 which is my bet
                            Alice the Time Capsule
                            • thebutterson
                              • 463
                              If you line up the cam with the boss on the head the valves will be closed, I checked with a spare head the other day
