M10 #3 Rod bearing
  • Smelser
    • Feb 2011
    • 633
    M10 #3 Rod bearing
    so, assembled a nice engine. new bearings new rings, honed the block. ready to race.
    plastigauge showed PERFECT oil clearence.
    in only 6 laps on a 3/8 dirt oval the engine locked when I came off and went to shift to 1st to go through the pits (we only use second on the track)
    Spun #3 rod bearing.
    thought it was bad luck till I disassembled the older engine and everything was useable EXCEPT #3 rod bearing. it was running fine but that one beareing was destroyed. good oil pressure FREQUENT changes. hard high revving life 4-6K all the time, every time.
    is there something about the #3 that can be fixed? blocked passage or something? it was two differant cranks, two diferant blocks.
    Thanks
    sigpic1984 318i Total conversion to a DIRT race car.
    Check out our build on facebook @ www.facebook.com/brewstermotorsports
  • TobyB
    • 5280
    Yes.
    You radius the oil port to #3 at the main. I make a pretty noticable divot with a die grinder
    and a 1/4" carbide cutter into the main bearing surface, then polish the edge of the cut.
    I THINK you make the trench
    on the leading edge of the hole, but it's been long enough that I forget, and the 'template'
    crank I have is buried... somewhere....
    I make the trench on the 3 bearings that feed the rods, just for good luck, but #3 is the one that
    feeds 2 mains, right?
    How fast are you spinning?
    t
    • TobyB
      • 5280
      here are a couple of linked images
      and with the rod, too, which I never did
      And looking at images, I also think I was drilling an extra delivery hole in the #3 shell, too.
      But it's been a while.
      t
      • Smelser
        • Feb 2011
        • 633
        7K on restarts, once I shift to 2nd, I stay there for the duration of races, 6 laps in heats and 15 laps in features, on a 3/8 clay oval
        usually sitting 4-4500 on the corners, then up too 6500 6700 before the next corner.
        • TobyB
          • 5280
          Do the crank mods and you should be fine- mine will sit on the 7500 rev limiter all day
          as long as the valve springs are ok...
          t
          • TobyB
            • 5280
            Does your oil pressure hold a steady 60 psi?
            t
            • petrolhead
              • 421
              This thread needs more pictures!!
              -Jarno
              • petrolhead
                • 421
                And I mean pics of the actual M10 crank mod or which ever parts you're talking about.
                • TobyB
                  • 5280
                  It's hard when the engines are all buttoned up, you know...
                  heh
                  t
