m10 turbo question.
  • ZomBAR15
    • Aug 2014
    • 103
    m10 turbo question.
    To all you m10 turbo guys. Could this plug here be used as an adequate oil return? It goes straight down to the pan. I have never really seen anyone use it as a return looking through pictures, so i am not sure
  • ak-
    • 12422
    If it's gravity fed with no problem then yeah!
    Has to be a straight shot down from the turbo.
    1991 325iS turbo
    • spdracrm3
      • Sep 2009
      • 959
      thats the block coolant drain (see coolant core plug right above it?)....i think you will find it does not go all the way thru to the oil return drain from cyl head circled in second pic, which explains why you dont see it being used as an oil drain
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • ZomBAR15
        • Aug 2014
        • 103
        Well damn i guess your right. At a glance it looked like it went through. But removed it and it was a coolant channel
        • thebutterson
          • 463
          Then what about using it for turbo's that are also water cooled?
          • ZomBAR15
            • Aug 2014
            • 103
            What is a good cam to use on an mild m10 turbo motor? Im thinking about ordering a 284° regrind? But i am not sure. Read alot of people saying factory cam works great, but would upgrading to a slightly larger piece have any benefit?
            • 2mAn
              Señior Mod
              • 21065
              Im using the 284 cam from Ireland Engineering.
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
