Auto to manual swap questions.
  • noypi2
    • Jun 2014
    • 442
    I'am swaping my M10 auto to manual. I already have a used Getrag 240 transmission, pedal, driveshaft, flywheel, new slave and master cylinder. What else do I need? Im buying new clutch assembly.Are there any parts from the automatic assembly I could just reuse for the swap. Thanks in advance.
  • TobyB
    • 5280
    Guibo? Speedo cable maybe (look at the numbers on RealOEM)
    Bypass the neutral safety start switch?
    Brake fluid reservoir and clutch hydraulics plumbing?
    Trans support and mount?
    Vinyl flame decals for all the extra speed you'll find?
    t
    • jonnywadster
      • Mar 2015
      • 58
      I use this pic as a good reference.
      I will be doing this soonish too, then turbo!!! lol.
      Good luck on your conversion.
