19 mpg...
  • noypi2
    • Jun 2014
    • 442
    19 mpg...
    My M10 average 19 MPG for both freeway and city driving. PO put Gen 3 green top injectors. Would this be the cause of my high gas consumption? or its something else...
  • packratbimmer
    • Dec 2009
    • 1334
    L-Jetronic is not an adaptive fuel injection system. I would get some stock injectors and try them. A properly tuned M10 can deliver 35 MPG on the highway and 22+ around town. 19 highway is way down there - something is wrong.
    BTW: Toss any weird plugs and use copper on the 318i.
    • 84driver
      • Aug 2011
      • 234
      I use newer 4-hole injectors (Mk3 2.0L Golf injectors, VW #037-906-031, Bosch #0280-150-955) and get the low to mid 20s, which is reasonable for how I drive. Is your O2 sensor busted? Have you checked the AFM? Does it smell like it's running rich?
      balticblau-metallic '84 318i 5spd 3.91 LSD
      • noypi2
        • Jun 2014
        • 442
        Forget to mention...its autotragic too..
        • packratbimmer
          • Dec 2009
          • 1334
          Still too low especially on the highway. Question: Any other non-stock parts on the car or just the injectors?
          Opinion as follows:
          BMW had the 318i tweaked for efficiency in those days (think 325e/eta). Any changes on the non-adaptive L-Jetronic are likely to be a tuning challenge and cause a loss in MPG. It can be done for sure, but a professional fine tune will certainly be in order. Back in the day, I found that advancing the timing and running 93 octane resulted in more MPG, but I had the domed higher compression pistons (not sure if that matters). Having said that, injectors could certainly be a factor. Newer injectors like so many other technologies have their own "signature." They likely atomize the fuel differently at the same flow rate, open and close faster/slower etc.
          I would suggest going stock and making one change to the the engine and management system at a time.
          • noypi2
            • Jun 2014
            • 442
            Just the injectors. Thanks for the suggestion. Anybody here have injectors available?
            • packratbimmer
              • Dec 2009
              • 1334
              See if MEPEH has any. They need to be clean and in recent service.
              • jonnywadster
                • Mar 2015
                • 58
                Mine got horrible gas mileage until I did a full tune up. seafoam, plugs, wires/cap/rotor. all fluids new air filter, and a new fuel filter.
                Start with the basics.
                • noypi2
                  • Jun 2014
                  • 442
                  Did all that except seafoam..still low MPG.
                  Sent from my SM-G920T using Tapatalk
                  • thebutterson
                    • 463
                    I have a set of stock injectors. They seemed to work fine before I pulled them. PM me if you're interested.
                    • packratbimmer
                      • Dec 2009
                      • 1334
                      30 year old injectors will need cleaning!
                      • Javier h
                        • Sep 2007
                        • 1189
                        M10 = 24 mpg
                        Period
                        • Smelser
                          • Feb 2011
                          • 633
                          Rock auto!!
                          My M10 gets a gallon of gas each week and does anywhere from 10 to 15 miles. but I am racing it at 7 thousand rpm.
                          note, uses about 3/4 of the gallon, every 4th week I dont need much gas , just to be safe
                          sigpic1984 318i Total conversion to a DIRT race car.
                          Check out our build on facebook @ www.facebook.com/brewstermotorsports
