flywheel spacer question
  • jonnywadster
    • Mar 2015
    • 58
    Hey I'm about to put my flywheel on and then the clutch to start buttoning up my auto to manual conversion.
    Does the flywheel bolt straight to the crank? or do I use a spacer?
    I know kind of a rookie question and I'm kind of a rookie :).
    Thanks gang!!!!
    Super excited to be done with this conversion, doing everything the right way and taking my time.
  • jonnywadster
    • Mar 2015
    • 58
    Okay I figured it out. thanks
    • TobyB
      • 5264
      The 'spacer', as you figured out, is more of a washer-
      it goes between the bolt heads and the flywheel.
      It's to keep the bolt heads from sinking into
      the flywheel, and loosening.
      In case someone actually uses the search sometime...
      t
      • jonnywadster
        • Mar 2015
        • 58
        Thanks again I'm really glad I didn't overlook it.
