e30 m10 manual flywheel bolt size?
  • jonnywadster
    • Mar 2015
    • 58
    almost done with the auto to manual swap so just a few more silly questions for you mo fos.
    what size flywheel bolts do I need for a manual flywheel?
    Arp or Oem? or can I reused my auto flywheel bolts?
    Thanks, I'm getting a clutch pedal assembly this weekend and I have to do the electrical part of the swap.
    Thanks again!!!
  • TobyB
    • 5297
    Depends on the flywheel-
    the OEM bolts are just fine, but buy them based on
    the car that you got the flywheel from.
    And keep in mind that most later ones have a spacer-
    and you should use that!
    fwiw
    t
    • jonnywadster
      • Mar 2015
      • 58
      You da man TobyB, thanks again.
      Happy thanks giving btw.
