E30 M10 with 2002Tii internals
  • niconoro
    • Apr 2017
    • 6
    hi, i have a stock, carbureted M10 and i recently bought some 2002tii parts, and i want to know how compatible are they.
    2002 parts:
    cylinder head with 292 degree camshaft
    pistons and rings
    conrods
    crankshaft
    head studs
    i have the following questions regarding this conversion:
    1- do i have to bore my block?
    2- does a e30 m10 intake fit the cylinder head?
    what other things should i take in count in order to make this work/ not blow up.
    thanks.
  • TobyB
    • 5288
    1. Depends on how big the pistons are. There will be a number stamped into them.
    You will have to measure the block. This might be a job for a machinist.
    2. yup.
    3. Not much. This should bolt together. You will find your rods match the 2002 rods. Buy ARP rod bolts.
    t
