5 speed swap help!
  • jonnywadster
    • Mar 2015
    • 58
    5 speed swap help!
    Hey gang I"m in the middle of my getrag 245/m10 auto to manual swap.
    I have a new flywheel/clutch on.
    clutch pedal etc is attached to car.
    but I can't find a 3 bolt output flange for my getrag 245 so that it fits my auto driveline.
    The auto drive seems to be short enough to work if I find a 3 bolt flange.
    adapter kit or otherwise, I'm on a relatives computer now but I will post pics of my progress.
  • TobyB
    • 5296
    Its been ages, but I think you need a manual shaft.
    The auto guibos are different/ bigger.
    Check realoem to make sure...
    t
    • loki_
      • Sep 2013
      • 147
      The guibo and CSB are all identical between the manual and auto (except the guibo bolts are 8mm longer). You'll need a manual driveshaft since it's two different parts. The manual driveshaft is pn 26104314372 and the auto is 26104314375.
      • TobyB
        • 5296
        Whoopsie, you're right- the M10 auto guibo is the same as the manual guibo.
        So just the front half of the driveshaft's different.
        My bad. Too many eta autos in my past...
        t
        • jonnywadster
          • Mar 2015
          • 58
          I found a output shaft off of a 2002 on ebay. Should work.
          Thanks guys
          • TobyB
            • 5296
            If it does, that would be news to me-
            let us know what happens.
            The 2002 crowd has scoured the BMW earth looking for a
            5- speed swap that doesn't require a driveshaft length change,
            and as far as I've heard, has never found one.
            t
