m10 engine mounts
  • Jean
    • 18228
    m10 engine mounts
    Besides IE mounts what other mounts that are stiffer than oem, but not solid metal mounts fit ?
    I found out AKG does not sell mounts for m10s after I called to order.
  • Rocla
    • 922
    Big six e34/e28/e32 mounts or e30m3 ones....
    EDIT: ... are not just plug and play, might involve some shimming, since m10 mount upper stud is eccentric, while all big six mounts are not.
    Check gustave's , s14 mounts should be a direct replacement for m10 mounts.
    http://www.e30m3performance.com/inst...ts/mounts1.htm
    Current:
    BMW 320i 2d 2.0 m20 -88
    BMW 325i Cabriolet 2.5 m50 -88
    BMW 316i touring 1.6 m40 -90
    BMW 320i 4d 2,2 m54 -01
    • Jean
      • 18228
      Thanks!
      • winstontj
        • Mar 2007
        • 500
        Jean - what did you decide to do? I'm looking for a better than stock alternative for MM's but I do not want to run solid/delrin mounts. I like the AKG e30m20 mounts - but only one side can be used for the m10. honestly I'm thinking about creating a shim for the passenger side mount and just running the e30m20 AKG modified mounts - but that will be a ghetto last resort type thing...
        My application is actually for an e21 but the mounts are the same.
        • Jean
          • 18228
          I went with off the shelf IE m10 engine mounts, they fit fine but you'll notice lots more vibration in the low rpm /idle.
          • winstontj
            • Mar 2007
            • 500
            That offset one is the problem... I'm going to use my e30 AKG mount for the straight through one and look for a different alternative for the offset one - Perhaps even re-drill the subframe or motor bracket. I really do not like the idea of using urethane that does not through bolt.
            M20 mounts were bad... I can only imagine what the m10 mounts are like... Must be fun though!
            • Jean
              • 18228
              I called AKG and they didn't have mounts for the M10, so I just went with what was available. My stock mounts were shot, one of the two oem mounts actually came apart when I removed them
              I raised my idle (via throttle cable) to 1200rpm, otherwise hood resonates...
              • brandon11130
                • Jan 2008
                • 635
                lol you adjusted yours to 1200, mine has been idleing at 1200 since i bought mine. guess i should get the mounts, i probably wont notice the vibration
                • deathtomine
                  • Jun 2008
                  • 206
                  I replaced mine on my m10 about a month ago and when i replaced them the old ones were in several piece! along with my tranny mounts. mucho better.
