M10 E21 running like crap!!
  • bimmer_E30
    • 5001
    ok got this car about 2 weeks ago . the car car runs like crap!!! misfiring in 2nd , 3rd , and 4th .
    the problem is that it pulls ok in first gear but once i hit 2nd its all over .
    any tips???
    Originally posted by e30e
  • kronus
    • Apr 2008
    • 13032
    Hands up if you saw this coming...
    cars beep boop
    • E30SPDFRK
      • 5716
      Byron
      Leichtbau
      • asubimmer
        • 6482
        prob rust in the intake
        • george graves
          • 20003
          First gear in a e21 m10 is SO low that a lawnmower engine would make that gear feel good. I assume you have done cap/rotor/plugs/filters?
          Originally posted by Matt-B
          • bimmer_E30
            • 5001
            i did the filter but not the plugs and such , do you think its the reason tho??? because it pullls ok in first?? i just need to fix the rust and drive the car .
            here is an example: went for a little test drive today . The car idles like crap . and then it will just idle high for a bit and then it will go back to Normal?? the engine is dirty as hell though , do you think with a little clean up things will be better?
            thanks for the help , i really appreciate it .
            • Jean
              • 18228
              Check all the vacuum lines yet?
              Clean the ICV?
              Clean the injectors and replace o-rings?
              Check and/or replace the spark plugs, ignition wires , coil, distributor/rotor?
              • george graves
                • 20003
                Oh yea, those O-rings dry up like little turds. Do a tune up - and get something to clean the valves. Always run chevron gas in a CIS m10 - helps alot.
                Like I said, first gear is a joke in e21m10's.
                • EN318isPDX
                  • Oct 2007
                  • 4373
                  you said.. i did the filter, can you clarify that? fuel filter or air filter? Both should be replaced.
                  • bimmer_E30
                    • 5001
                    soory guys !!! i only did the air filter , but thanks for the input . just orderd my tune up kit !! i will keep you update.
                    • SpecM
                      • Oct 2005
                      • 4531
                      ummm...
                      ...yea
                      1989 cirrisblau-metallic 325i
                      • bimmer_E30
                        • 5001
                        lol i am an idiot.
                        • EN318isPDX
                          • Oct 2007
                          • 4373
                          lol i am an idiot.
                          We are aware of that but what about developments with the rust bucket?
                          • bimmer_E30
                            • 5001
                            i am trying to cover the rust as much as possible.i am just busy with work and school now . also i just got a call from a freind , telling me that there is a 323i E30 for sale for 500$ . if it has the euro bumpers am getting that car .
