84 318i questions
    84 318i questions
    i just recently picked up a white 84 318i coupe.
    few question i have that i cant seem to find anywhere on the boards
    recomended engine oil weight?
    can i run synth?
    also the blower motor in my car doesnt seem to be running at all when im on the highway i can feel the air blowing through the vents so im getting flow just no power behind it
    any ideas?
    thanks for your input,
    thegrillman
    bump
      castrol 20w50
      and you can, but it might make your engine leak, besides its a m10, 20w50 will be fine.
      &, the resistor might be bad in it.
        if the blower doesnt work in any speed its probably either not getting power or the motor is bad. the resister only controls speeds 1 and 2
        First: 1984 318i
        Second: 1987 325
        Third: 1987 325is
        Current: 1990 325i (Soon To Be 335i)
          yes not running at all
          where exactly would i check for power?
          in the access pannel in the bay? or do i have to go in through the dash
            Pop the hood and check the fuses. The access panel is behind the intake manifold, on the firewall. Easy to remove. Under it you'll find a blower fan and a resistor on it.
              actually i dont know how to reconect it haha it was off and kinda proped up when i bought the car
              seems like everything is connected ill check the fuses in a bit and see if any are blown
              also the highly anoying buzzer that go's off when ither door is open and the car is running
              how do i disable it?
              gotta be a fuse or something along those lines
              thanks for all of your help guys
                just drop the panel above the pedals and un plug it.
                First: 1984 318i
                Second: 1987 325
                Third: 1987 325is
                  thanks for the detailed explanation
                  i guess trial and error are my friend
                  thanks for the input
                    do you really need pictures and a full write up to remove 3 half turn plastic screws?
                    First: 1984 318i
                    Second: 1987 325
                    Third: 1987 325is
                      i know how to remove the halfturn plastic screws
                      i just figured there is a good amount of wiring and plugs beneath that and im suposed to know what to pull?
                      thats why i said trial and error are my friends
                        its a little black box that clips on to the panel. if you take it apart you will know exactly whats there. lol.
                        :ninja:
                        OPM Autosports
                        Myspace
                        1984 325e... SLOW.
                          leave the door open and unplug the thing making noise
                          First: 1984 318i
                          Second: 1987 325
                          Third: 1987 325is
                            :ninja:
                            awesome thanks for the info
                              see i didnt know that it made noise from under the dash i also wasnt sure how things were connected
                              but thanks
