Fuel Pumps Not Kicking On
  • 1990e30coupe
    • Jul 2010
    • 126
    Hi,
    So I have been searching on this site trying to find some ideas on where to start searching for my issue and I haven't come up with much as everything that pops up in my searches are intermittent running or poorly running pertaining to fuel pumps.
    I have a 1985 318i that was a shell when i got it. The body was nice so i found a motor did a complete rebuild and pieced the car back to life over the past year. The issue I am having is that the fuel pumps will not kick on at all. I have tested for power at relay everything checked out, and put a new relay in just for the hell of it. If I Jumper at the relay I can get the fuel pumps to run and the car runs great. So the computer sends signal to that relay according to my Bentley, but is there a signal for the pumps to that relay from something else or am I focusing on the wrong area? I can jumper the pumps at the ignition but want to fix it right. Any ideas or leads on what to look for would be greatly appreciated.
    Also I am not finding a specific relay for the fuel pumps as they just run off the main relay that sends signal to the AFM, TPS, and Fuel Pumps. I don't have an O2 sensor in yet but i don't think that would cause this issue. I am not that great with wiring; therefore, before I start getting into that being an issue I thought I would come here first and see if i could get some ideas before searching myself.
    What BMW means to me: Breaks My Wallet
  • Sunnyledge
    • Nov 2017
    • 221
    On another website, Richardodn posted a google doc ( https://docs.google.com/spreadsheets...it?usp=sharing) that he compiled for diagnosing many E30 issues, including the fuel pump. Excellent.
    • Gregs///M
      • Mar 2012
      • 2459
      Crankshaft Position Sensor CPS, is the sensor that sends signal to the DME, which in turn will trigger on the fuel pump. Replace your CPS and I bet your fuel pump will work again.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • 1990e30coupe
        • Jul 2010
        • 126
        Thank you as that's exactly what i was looking for. Much appreciated.
        • 1990e30coupe
          • Jul 2010
          • 126
          There is no CPS on these older M10s that i know of unless in the distributor, but even then unlikely. Maybe a signal from the speed sensor. I would think there has to be a crank or cam signal from somewhere, but then again i am not too familiar with these M10s.
