Good Injector upgrades?
  • E30_Beau
    • Mar 2021
    • 25
    Hi all
    I've just finished up putting together a M20B27 stroker for my E30 and I was wondering if I might be able to get a little bit more out of the car with some larger injectors?
    The basic details for the engine are:
    M20B27 block
    731 cylinder head ( ported)
    2.5 inlet manifold and throttle body
    Megasquirt MSPNP2
    288/288 Camshaft
    Bosch 0 280 155 844 injectors ( ford 4.0 6 cylinder)
    Other than that it has a standard crank, rods and pistons.
    The fuel rail, fuel pump and regulator are also the factory one for a 325i.
    The injectors that are currently in the engine aren't a performance upgrade as such, I am using them simply because they are similar to the factory set but with a 4 hole tip instead of the single hole tip.
    any suggestions would be great even if someone recommends a fuel rail upgrade etc.
  • digger
    • Nov 2005
    • 6213
    Those Ford 19lb/hr injectors are plenty enough. There are no legitimate upgrades to be had for your fuel system unless something is broken or malfunctioning no need to replace anything . What you should spend money on is aspects of tuning e.g wideband etc
    • 808ETA
      • Nov 2018
      • 436
      Curious where you got your head. I had someone building a head for my 84ETA however I don't think I'm going to get it so I'm looking for another source.
      sigpic84 325e
      • digger
        • Nov 2005
        • 6213
        Which one ? The current one I got from MM years ago like 2006 iirc which is currently on the car. I had one done by knight engines but have been pretty slack assembling the rest of the engine
        • 808ETA
          • Nov 2018
          • 436
          Sorry, I meant to ask E30_Beau but if you have a source that would be appreciated. Where is Knight Engines located?
          sigpic84 325e
