Oil pressure question?
  • turbski
    • Jul 2018
    • 329
    Got a couple hundred miles on the new motor and have noticed my oil pressure hot under load sits up in the 70s. Hot idle is around 25. Cold start is 75. I run 10an lines from block to the filter and oil cooler. Oil is 20w50 high zinc for break in.
    anything to think about or is that normal.
    From what I've read the hot idle is normal but the hot under load and cold start seem to be on the higher side?
  • reelizmpro
    • 9559
    That's fine
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
