Loud Ticking Noise in Interior
  • Chebyshev
    • Aug 2007
    • 46
    My '90 325iX (manual swapped) has a relatively loud ticking noise that varies with RPM in the interior. The valves aren't much louder than I expect with the hood open and I recently adjusted them properly. It is like the valve (or injector) ticking is being amplified to the driver's seat.
    I tried plugging the hole in the middle of the steering wheel with my finger and it made no difference (https://blog.fcpeuro.com/how-to-fix-...e-bmw-e30-325i).
    Thoughts?
  • roguetoaster
    Biggus Tippus
    • 7795
    Not an ix person, but Isn't that some type of t case issue?
    Alternately, remove the cartoon explosive from your car.
    • ovo_e30
      • Aug 2020
      • 34
      I had a similar issue recently. The firewall grommet in the rear of my glovebox came ajar while fiddling with some wiring. It resonated a ticking from the engine bay into my cabin which was very noticeable when the glovebox was closed. It echoed into my glovebox badly. I reseated the grommet properly and the ticking vanished.
      • Chebyshev
        • Aug 2007
        • 46
        That's interesting, I'll take a look behind the glovebox.
        In that vein, are there supposed to be grommets in the firewall for the steering column and heater hoses as well? I think I may have just holes for those things right now. Perhaps that's the issue.
        Maybe I need #6 in https://www.realoem.com/bmw/enUS/sho...diagId=32_0492
        • Chebyshev
          • Aug 2007
          • 46
          Just to close the loop on this one:
          I went out and found that a couple rubber grommets were not properly installed in the left side of my firewall, but were just dangling from the brake reservoir line and steering column. There was also an empty hole over by the fuse box. The grommets I reinstalled with the help of some assembly lube and the hole I plugged with a piece of wine cork.
          The cabin is quiet now!
          • ovo_e30
            • Aug 2020
            • 34
            Great to hear you got that sorted out. It’s always the small details lol
