Pretty certain I have an oil leak between cylinders two and three on the exhaust side. It appears to be coming from the head gasket area and running down the side of the block. It does not appear to be coming from the valve cover gasket and running down the head.
This is not a large leak (not dripping on the ground). However, I am doing a timing belt this weekend and replacing a couple oil seals on the front of the engine. I do not want to mess with the hg unless that is an area (between 3 and 4) where pressurized oil goes through the head gasket. The head gasket has no coolant-related problems.
