Vibration, engine ticking and rattling.
  • Hartacus
    • Dec 2016
    • 44
    When my car is at idle it vibrates that I can feel it in the steering wheel. Then over 2500 RPM when im on the highway it starts to vibrate a lot.
    When I start the car I hear a ticking and a rattling almost like metal clanking together. I made a video and you have to listen carefully for the clanking, some reason the microphone didn't pick it up that well but it's much louder in real life.
    https://youtu.be/5SMqalkoFdQ">https://youtu.be/5SMqalkoFdQ" type="application/x-shockwave-flash" width="425" height="350">
    Is this due to a misfire? Any ideas on what could be the problem?
  • McGyver
    • 4636
    Sounds kinda like a loose accessory slapping around, like our alternator or fan.
    • Hartacus
      • Dec 2016
      • 44
      I changed the spark plugs and it's a lot better but still vibrates. I hope it gets better when I replace the cap, rotor, and coil. I recorded another video with better audio of the clanking. Could it be a loose pulley? After the car warms up after a while or I drive it the clanking noise dissipates or goes away.
