Valve cover gasket
  • Tom Galloway
    • Dec 2018
    • 133
    Valve cover gasket
    Is it necessary to get new/ plus rocker plugs/ every time I adjust the valves.
  • e30vert
    • Jan 2005
    • 1789
    I think the Bentley calls for replacement of those plugs , but I dont unless after I button everything back up and torque the valve cover nuts to 11 foot pounds of torque using a star pattern thier is leakage. Its a good practice to use some RTV over the top of those rocker plugs as those points are sometimes tougher to get to seal up.
    • Tom Galloway
      • Dec 2018
      • 133
      Good the RTV is a plan
      • bangn
        • Sep 2011
        • 760
        If they've been replaced recently and not 50k miles ago you can just reuse everything. Il put a smidge of 515 around the moon section but ive never put it on the flat. Just my personal pref. Ive had my cover off a heap and never had a leak.
        Boris - 89 E30 325i
        84- E30 323i
        • Tom Galloway
          • Dec 2018
          • 133
          Good, 'don't want to get to anal about it.
          thanks
          TG
          • digger
            • Nov 2005
            • 6194
            When rubber gets really hard it’s time to replace
