Engine Compression leakdown test
  • Jako212
    • Jan 2024
    • 31
    Hey fam,
    took my car to a shop to do leakdown and compression test
    car shakes when at idle but hasnt been driven for 3 yrs
    here is results
  • laidback93
    • Nov 2016
    • 435
    Hate to say it, but the results don't look good, especially cylinder 3. Might indeed be time for a rebuild.
    I've tracking down a cold start idle issue and slight misfire. Regular compression test revealed 115-120 in all 6 cylinders. This was a couple years ago and the results still surprise me as the engine off idle pulls silky smooth and hard.
    90 Bronzit 325is
    16 Black Sapphire 340i M Sport
    • Jako212
      • Jan 2024
      • 31
      So what did you end up doing because im kind of stuck on what to do you think rebuild or just swap a new engine inside?
      • laidback93
        • Nov 2016
        • 435
        I'm still having issues, but want to rule out other items before a rebuild. I swapped in another M20 about 3-4 years ago and the same cold idle issues are happening.
        That being said, swapping in a verified healthy M20 will be much cheaper than a rebuild. Just verify compression before you buy if you can.
        90 Bronzit 325is
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5604
          rebuild it.
          You might pop in a used one that works for a while, but no used engine will last longer than a properly rebuilt one.
          cost is obviously something to consider, so if you're going to keep the car long term, rebuilding is cheaper in the long run. If the car is something you might want to sell in the coming years, just put a used one in it.
          • Jako212
            • Jan 2024
            • 31
            Either rebuild it or buy a new e30 sell this as is?
            found one with an m50 8k price but its a four door
            • laidback93
              • Nov 2016
              • 435
              rebuild it.
              This is the approach I'm going to take if my current M20 is truly in need of a rebuild. I plan on keeping my 325is for a long time and don't want to play engine roulette again.
              90 Bronzit 325is
