i head swap question.
  • slo325i
    • 417
    Before anything, I need to mention that my 87 325i has a 86 eta motor in it. Don't ask why, the PO decided that's the motor he wanted. I guess the cool thing is that all the electronics and the wiring/ecu is for the i motor but the eta still runs fabulous with it.
    Now I'm growing a bit sick of the 4500rpm limit that I constantly have to be aware of since my ecu is for the i motor that supposed to rev 6000+
    My question is, if I sourced a 87 325i head and all the accessories on it, could I just swap it with the eta head and keep the eta block that i have on now? I mean, the car is made for a i motor. And I have all the i electronics in the car now running the eta motor. Would this work? Please enlighten this noob.
    Justin
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
  • E30_fiend
    • Apr 2006
    • 7348
    yes
    but there may be a few things left to wire up or replace to make it work. It all depends on how thorough the previous owner conducted the swap.
    Taylor
      That is doable and will result in a "budget stroker" In this case you'll need an I head, intake, and throttle body.
      • slo325i
        • 417
        I mean, i did notice a few connectors that were left unhooked and dangliing. But otherwise, seems like like a pretty straightforward swap.
        Originally posted by E30_fiend
        yes
        Taylor
        • slo325i
          • 417
          It's already running a i throttle body, icv. What about the fuel injectors? are they the same between the eta's and the i's?
          • slo325i
            • 417
            Also if I replaced the head with the i head, I get my 6000+ rev limit back right??
            another question. If i had the eta block and i head, as you call a 2.7i, which timing belt would I need to get? one for the eta or the i?
            • 416stroker
              • May 2008
              • 2448
              ya you can rev it it will be fine I had one and it revd to 6900 no problem you should get the head milled to bump the comp. ratio up.
              84 318I Delphin RIP
              87 325IS delphin 24v Sold
              89 325 Alpineweiss
              • 416stroker
                • May 2008
                • 2448
                I ran an I timing belt didnt know they were different.
                84 318I Delphin RIP
                89 325 Alpineweiss
                • slo325i
                  • 417
                  Thank you!!!
                  • 416stroker
                    • May 2008
                    • 2448
                    theres a lot of info on the 2.7I read up youll learn a lot about it .
                    84 318I Delphin RIP
                    89 325 Alpineweiss
                    • slo325i
                      • 417
                      I appreciate you letting me know. I've been reading alot up one these "budget strokers." Now if i could only source a good i head. Anyone???
                      • 416stroker
                        • May 2008
                        • 2448
                        Just get one from pnp and build it with a 272 reground cam from ireland. It wold be pretty sick. I think BFC has some great info the build up. The head should be milled like .020 or somthing.
                        84 318I Delphin RIP
                        89 325 Alpineweiss
                        • slo325i
                          • 417
                          Gonna build for reliability and simplicity for now. I've been searching for this one answer though. Which afm would the 2.7i require? the eta one or the i one?? Also about the fuel injectors? eta or i injectors??
                          • 416stroker
                            • May 2008
                            • 2448
                            The I one for both questions. I dont know which are bigger?
                            84 318I Delphin RIP
                            89 325 Alpineweiss
                            • kenika65
                              • Aug 2007
                              • 1336
                              click on my 2.7i how to in my sig all answers will be answered then if you still have questions ill be glad to help!
                              1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                              1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
