1985 325e m20b27 cranking
  • Ericmc34
    • Apr 2024
    • 2
    Need some help with issues on my 1985 325e ran flawless before doing clutch and rear main on car but now car will start then die car only been not running for 2 weeks replaced both sensors on bellhousing new plugs and fuel pump what else would cause this from just doing a damn clutch
    All the parts that I have change in past year
    2 bellhousing sensors
    ​​​​new fuel tank
    new in tank fuel pump
    Spark plugs
    clutch kit
    Rear main
    Harness
    Alternator
    All fuses​
  • 82eye
    • Jan 2009
    • 2099
    jumper the pump and see if it stays running. sounds like it's starting on the cold injector but the mains aren't kicking in.
    • Ericmc34
      • Apr 2024
      • 2
      I can't get it to even stay running with giving it gas
      • 82eye
        • Jan 2009
        • 2099
        did you replace both pumps or just the in-tank ? do you have fuel at the rail ? did you check pressure at the rail ?
        • tomstin
          • Mar 2015
          • 569
          ran flawless before doing clutch and rear main ​
          Did you replace / resurface the flywheel? Is the tang still there that the reference sensor uses? If new flywheel, is it the right one with the tang? When you replaced the reference and speed sensors, could you have reversed them?
          2004 525i Manual - 1985 325E Coupe Manual
