Rough Idle - Cam timing?? 325es
  • 82eye
    • Jan 2009
    • 2108
    if it's just idle test the icv. there's piles of them failing now with age. e's seem particularly prone.
    • Chuck-Michigan-e30
      • Jun 2024
      • 9
      I found out an employee did not install the woodruff key at the crank/timing pully. Thanks
      • BadDays
        • Dec 2024
        • 186
        Working ICV's are like endangered birds now, They will all eventually go flat on their face without any replacements, If you can't find a working 325e ICV, Try to see if you can adapt something else that'll work with the M20.
        • udubfl
          • Aug 2022
          • 76
          So, your rough idle is corrected?
