M20 45mm welch aka core plugs (DO NOT USE FEBI)
  • zaq123
    • Jul 2016
    • 1570
    Just a word of caution, do not use febi Welch plugs when rebuilding your engine. I built this stroker a while ago and used Febi plugs ($1 vs $10/each for OEM). One started to drip so I pulled it out, found why it was leaking (defect in the plug edge that no loctite 540 could seal) and ordered a set of six new plugs. Well looks like all 6 are of a terrible quality. Like all are messed up like the one I pulled but worse, Febi is probably having China make these anymore.
    Replacing core plugs while the engine is installed and everything bolted isn't fun job.
    So it looks like only two choices are left for these M20s, OEM steel for $10/ea or quality aftermarket bronze for $5.50.
    A damn core plug... how can one mess up its production? Stay away from FEBI core plugs.
