Break-Out Cable for the DME
  • 66Vette
    • Feb 2023
    • 19
    Does anyone know if someone makes a break-out cable for the DME. I'd like to look at various signal lines without cracking open the case.
  • TobyB
    • 5298
    I have not found one.
    I once bought a socket to make one,
    but then went a different direction.
    I think the sockets are still available, so you don't
    have to tear apart a DME. The plugs come from the junkyard...
    t
    • 66Vette
      • Feb 2023
      • 19
      Thought I would follow up. I haven't found a complete solution to a breakout box. The closest thing I have found is this:
      https://www.ebay.com/itm/334950044405
      It looks like they don't have the male connector in stock so you can only buy the board. You would also need the female connector to put together something resembling a breakout box.
      • TobyB
        • 5298
        Y'know, I think I got the male connector from them, back in the day.
        One of the rabbit holes I fell down was figuring out which connections I might
        want to interrupt for testing and diagnosis purposes. Then boxing,
        tagging out for data logging, and such, and by the end of it all, I think I had
        plans for sticking an Arduino Mega in there as well???
        t
        mission creep
