Crank / No Start Solved. Now 1222
  • JerEazy
    • Jun 2025
    • 35
    1990 325i
    Went from a died while driving to a crank no start. Did some searching and confirmed fuel, confirmed compression, spark was the issue. Doing some quick reading of things I can test/replace the coil came up. Figured it was a long shot because failure is rare. But, had an old coil on the shelf I knew was good. So swapped them this morning and bam! She’s running.
    The idle is steady-ish. But coming off of a throttle blip in neutral she stumbles before catching and leveling. Also threw a new check engine code that was not present before 1222.
    i did a smoke test as part of the checks for the crank/no-start and there aren’t any leaks. The injectors are new - and the AFM is a bavrestoration remanned. I have another one I can swap in (has a chewed up stud I can swap out). But what checks should be I looking for?
    as a side note: if I hold the throttle at say 2k rpm the check engine will go away. O2 sensor, engine temp sensor, and FPR replaced in last 300 miles while I was doing valve job and injector replacement.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5616
    Check TPS adjustment. Might not be hitting the idle switch
    • JerEazy
      • Jun 2025
      • 35
      TPS adjustment has been checked and confirmed.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5616
        Check to see if the ICV is really working.
        Unplug the valve itself while the engine is running. You should see the idle climb to 1400ish RPM
        Been seeing a lot of cars where the DME keeps the ICV slammed shut and the car bogs as it comes down to idle a few times until it evens out
        • JerEazy
          • Jun 2025
          • 35
          Swapped plugs and didn’t help. Did another smoke test to confirm and nothing leaked.
          swapped AFM and started it. She bounced around quite a bit but after about 30 seconds steadied in and no check engine light. So a bad coil and bad AFM has me wondering what on the electrical side could cause that issue.
          but for now I’m happy she’s running again.
          • JerEazy
            • Jun 2025
            • 35
            Idle is a little low for my taste and gives a shake. But she runs beautiful under throttle.
            wonder if I’ve got an ECU issue.
