Oil leak by cam seal
  • 3VOLV3R
    • Apr 2026
    • 3
    Bought this car a few months ago and have had a oil leak sense. Took it down to do a timing belt change and found attached in the photo. Does this look like a cam seal leak or a head gasket? It looks like the can seal is the highest point of the leak.
  • 82eye
    • Jan 2009
    • 2078
    you'd likely notice other issues with a head gasket leak. do the cam seal and replace the valve cover gasket and D-seal plugs. take the opportunity to adjust the valves after the timing belt / water pump / cam seal change.
    • 808ETA
      • Nov 2018
      • 436
      Get some UV oil dye to find the source
      sigpic84 325e
