piston options for NA stroker
  • structured
    • 954
    I'm planning to use an eta bottom end with my i block and i head. I don't plan on FI so I'm looking to go pretty high compression. There is a ton of info on turbo/low compression options but not so much NA. This is probably due to the fact that there is little power to be gained NA, but I don't want to start that argument so keep it to yourself.
    I know that I can use the i pistons or maybe some from a euro eta(valve-piston interference?), but I am curious as to what other options there are.
    Custom, oem, aftermarket?
    What's out there?
  • atomic
    • Jun 2007
    • 5691
    UBER RARE!!!
    :up:
      • 34839
      if I were to do it again, i would go with MM's rallye pistons (11:1) and the schrick 288. I would also have gone with the 84mm crank instead of the eta crank.. the whole thing would have only cost a few hundred bucks more.
      • guibo09
        • Dec 2008
        • 834
        why not the 89.6?
        90 E30 325i
        • structured
          • 954
          whats pistons and cam did you use instead?
          • SpecM
            • Oct 2005
            • 4531
            Originally posted by guibo09
            why not the 89.6?
            cuz they're more expensive?
            1989 cirrisblau-metallic 325i
              • 34839
              mm sport pistons and a 284/272
              it's not bad I just wish for a little more. ;)
                • 34839
                and harder to find.. there were a couple 84mm cranks out there when I was looking. Ended up getting a 2.7 bottom end on a trade for a 3.91 rear diff.
                • SpecM
                  • Oct 2005
                  • 4531
                  good combo imo
                  did you go with .5mm oversize?
                    • 34839
                    2mm, anything less is a waste IMO when pistons cost over $1k :p
                    • structured
                      • 954
                      Do you guys have opinions on buying used pistons? ie. the ones linked above?
                      I'll keep MM in mind, but for now I'm feeling out the budget build. Putting $3-4000 worth of motor in my $2000 car doesn't make sense right now.
                        • 34839
                        it'll never make sense. Most budget builds aren't worth anything, you really have to go all out to get anywhere with an M20.. that's why so many people swap in E36 motors.
                        nothing really wrong with used pistons if they are in good shape, you just have less options for what you can do with CR, displacement, and weight.
                        BTW flat top pistons aren't going to be so great in the 885 chamber, you're going to lose out on all the quench area that makes the 885 a pretty decent 2v design.
                        • structured
                          • 954
                          I'm aware of all of this, but I'm just looking to have some fun building then driving a motor. My M20 currently leaks oil from just about everywhere and I'm pretty sure that coolant is leaking through my headgasket.
                          Also, I don't want to have my car apart for a long period of time, so I want to build a motor separately and be able to swap it in without major fab.
                          So now maybe you can see why I am not looking for other swaps. Just want something that has been refurbished and is fun to drive. I have enough fun with my 230k mile M20 as it is.
                          Thanks for your input to this thread btw, it's been helpful. :up:
                          • guibo09
                            • Dec 2008
                            • 834
                            off topic: do you need an oversize head gasket or is a stock replacement good for 86mm?
                            90 E30 325i
                              • 34839
                              stock is fine
