m20 10:1 2.9L stroker compression test results
  • zaq123
    • Jul 2016
    • 1563
    Ok to start of: the gauge is verified with an accurate pressure gauge and they line up perfectly after 50psi (comp. gauge is 300psi so less resolution than accurate test gauge). schreder valve is located at spark plug end so the hose is out of picture as it should be.
    ITBS are fully open during the test. Hot engine.
    2.9L 10:1 Mahle pistons. block was shaved just to get level. stock head gasket thickness, cylinder head is not shaved (new AMC). Cam is 284/272 Schrick 3 degrees retarded.
    cyl1 -255psi (was the first in the test so maybe why a little higher), cyl2-6-250psi exactly. Dry test, injectors disabled all that. Compression rises in following order as the crank rotates, the same for all 6 cylinders: 0 --- 90 → 140 → 155 → 180 → 200 PSI (5 cranks) and then increments in 5ps for each crank to 250 total (about 10 more cranks to plateau at 250psi).
    Why is my compression so high? I didn't test the gauge after 150psi as my accurate test gauge is 150psi max but I don't see it being too much off.
    Any ideas? Did I over cranked it, I mean normally you crank till gauge stops. No crazy carbon buildup based on my borescope. There were some rich issues initially when the tune was being dialed in but it has been 10k km ago. I can actually read markings on piston now.
