possible afm problem?
  • bmwlover0725
    • 36
    I've replaced everything you could possibly think of in the engine bay except for the afm. When I say everything, I mean everything. I even recently rebuilt the engine and compression is fine. Everything checks out good. I've got an air/fuel ratio gauge and it's telling me that I run lean most of the time. I have surging acceleration and a slightly rough idle. The idle gets even more rough upon turning on the A/C. I also haven't replaced the ECU yet, but I think it's the AFM. It's been adjusted several times and does nothing each time I adjust it. The fuel injectors are fine as well. My fuel filter is about 10k miles old and needs to be replaced, but I don't think it's so clogged that it's causing this much of a performance loss.
    Can somebody help?
  • slo325i
    • 417
    Maybe try cleaning the afm with that spray cleaner??
    Also spray some carb cleaner and scrub with qtips on in the ICV. It helped me with my idle issues a quite bit.
    Good luck
    Justin
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
      • 34839
      how lean is it running? if it's running more than about 15:1 at idle, it will idle roughly.. lean running can definitely make it surge on acceleration too.
      • bmwlover0725
        • 36
        it's running pretty lean. I know it's definitely running too lean. It also misfires slightly and will go fully lean for just a sec. I have replaced EVERYTHING else like I said. I'm thinking it's a broken AFM because no matter how much I adjust it, nothing changes.
        • Knockenwelle
          • Jul 2008
          • 395
          Don't rule out vacuum leaks until you've ruled out vacuum leaks.
          Mike
          '91 325i track car. Mostly...
