MarkD & 19# injectors - just plug & go?
  • RoDo
    • Nov 2008
    • 104
    I've searched and tried to find the definitive thread on this but no luck. I've got myself a shiny new MarkD chip spec'd for my M20 at 91 octane w/19# injectors. I've also got myself a somewhat less shiny set of cleaned 19# injectors.
    From what I read installation sounds like:
    1) Install chip
    2) Install injectors
    3) Start her up and idle for ~5 minutes
    4) Flog the car for 15 minutes or so
    That it? Do I need to go through any more complicate procedure or is it really that simple?
    Thanks!
    1987 325is
    --- used to haves ---
    1988 325is
    1999 540i/6/Sport
    1989 325iX
    1998 M3
  • xLibelle
    • Aug 2004
    • 2673
    Yes.
    Doesnt need to idle for 5 min. Just putt about easy-like. Its better to feed the computer some variation.
    • Prestige
      • 79
      plug it in let the car warm up then "drive it like you stole it"
      thats what i did sorta...
      • RoDo
        • Nov 2008
        • 104
        Sweet!
        1987 325is
        1988 325is
        1999 540i/6/Sport
        1989 325iX
        1998 M3
        • digger
          • Nov 2005
          • 6194
          plug it in and just drive......
          • Fingprep
            • Nov 2008
            • 27
            Do the 19# injectors do anything (or even work) for the chipped etas out there?
            • jmc1590
              • Jul 2008
              • 112
              Off the top of my head, no. But that depends on which eta we're talking about. The pre-'87 eta, using Motronic 1.0, already has 18# injectors. Low impedance injectors, so the standard 19# will not work properly. The s-eta with Motronic 1.1 is a different animal. Apparently the stock injector (716) is a 12.5# high impedance unit. In that case, yes, the 19# upgrades will work. (Can't say I've seen a M1.1 chip though...)
              Need more fuel for an eta? Look at the 201 injectors from a M30B32 (533i,733i). 24#, low impediance. There's your eta upgrade.
              • E30_fiend
                • Apr 2006
                • 7348
                yes, the 19lb injectors do something especially the design IIs
                and no the 19lb injectors wont work in an eta. The super eta is, like posted above, a completely different animal. The fact that the eta injectors are low impedance makes swapping them out completely out of the question.
                • R3CKL355
                  • 11
                  i have nothing done to my car (1990 325i) apart from the gutted cat, can i throw in the same setup? #19 injectors and a MarkD?
                  sigpic"Its ugly.."
                  "Thanks!"
                  • xLibelle
                    • Aug 2004
                    • 2673
                    you should change the oil for the heffer shaft for it to work better
                    • E30Idea
                      • Mar 2007
                      • 2196
                      lol
                      ** Lot's of M20 turbo parts for sale.**
                      Turn key track car.
                      http://www.r3vlimited.com/board/showthread.php?t=222066
                      • funcrew
                        • Jun 2007
                        • 1223
                        Maybe too obvious to say, but make sure your gas tank is full of the 91 octane the chip requires, or the engine will detonate. I'm having to wait until I burn up all my el-cheapo low octane gas before I install my Mark D 91.
                        "If the sky were to fall tomorrow, the tall would die first."
                        -Dr. Paul Forrester
                        Do I LOOK like I need a psychological evaluation???
