327i SWAP Quick HELP!!
  • Luis325
    • 3847
    Im doing the swap with my 1986 325es block and pistons and im installing an 325i head (885 head?) and intake mannifold, TB, etc.
    My question is the wiring harness, AFM and ECU i found available here are from a 1989 or 1990 325i. Would these work????
    Thanks
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • Devil Inc
    • Jan 2008
    • 802
    Yes those should work.
    • Van Westervelt
      • 9365
      Wiring harness will be different. You have an early model harness, therefor you will want to find an 87 325i harness.
      • Luis325
        • 3847
        So they would work? I got them as a package with the whole head, afm,etc.
        Would really suck if it doenst work and have to spend more $ on another one...
        Also does the ecu need to be any particular year? The one I have is 1989...
        Thanks
        • Luis325
          • 3847
          ok so I would need to get a 1987 I wiring harness , ecu (1987? Or can be 1989-90) and afm fron what year?
          • Van Westervelt
            • 9365
            AFM and ECU arent year specific in this case I dont think. But you have an early model and need to use an early model 325i engine harness.
            • Luis325
              • 3847
              OK Thanks Man for the quick repply!!!!
              Im going to be ordering everything today, to see if I can start my swap next week.
                You can use that harness if you are willing (and able) to modify it slightly. If you want ot go that route I can dig up the data on what I had to do to use a 1990 harness in my 87 325is.
                • Brian 89 325i
                  • 1450
                  So Im doing this swap next week also (ex the head) and I have an 87 325. I have a harness from an 89 325i, this will work correct?
                  Sorry for the thread jack
                  Brian
                  • Luis325
                    • 3847
                    Its ok. as long as the ECU and AFM dont matter that they are 1989 because the wiring harness i can change for a 1987 325i without any problem!!!
                    Thanks
