possible to upgrade m20 TB with M30 TB
  • p0cket penguins
    • Jul 2008
    • 481
    Hey guys,
    Last night I saw two coolant lines running to my M20 throttle body (on the track only e30). I was thinking about looping it but I remembered that the m30 throttle body didnt have these lines. I was wondering if the m30 throttle body will bolt straight up to the m20?
    thanks
    Chris
  • Erick
    Official R3V Drifter
    • 11169
    Originally posted by p0cket penguins
    Hey guys,
    thanks
    Chris
    That's a negative sir.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • p0cket penguins
      • Jul 2008
      • 481
      whoooomp whomppppppp.... ok well ill just connect the coolant lines together with a brass fitting and take off that plate.... also has anyone relocated there coolant tank... Mine is on the driver side and i want to make a super sweet air box... if i could move it to the passenger side that would be great
        • 34827
        it would be easier probably to move the intake to the passenger side. that's my plan anyway.
        • SpecM
          • Oct 2005
          • 4531
          ooh more details on that?
          1989 cirrisblau-metallic 325i
          • Erick
            • 11169
            And a reason why you'd want to move the intake to the hotside please :p
            Feedback Thread
            • SpecM
              • Oct 2005
              • 4531
              probably get a more direct and straiter airflow
              and proper sheilding would be a must, yes
                • 34827
                I mean the filter itself. there's a huge open area behind my passenger headlight, or the crowded area on the drivers side which is also occupied by the radiator outlet and resivior.
                • p0cket penguins
                  • Jul 2008
                  • 481
                  but cant you just get an early model coolant tank and put it where the early model ones are?youd have more space.
                    • 34827
                    I could but my ABS and cruise control would still be in the way, and I'm not removing those just for an intake. :p
                    • RobE30
                      • 959
                      Hey guys,
                      thanks
                      Chris
                      I tried to make the m30 tb work.... didn't happen. If you swapped to an earlier radiator you could move the coolant tank to the pass side or maybe an m42 radiator?
                      09 BMW 328xi touring 6spd
                      05 Subaru Outback XT 5spd
                      87 BMW 325is
                      a few bicycles
                        • 34827
                        btw, apparently the temperature that is most likely to form ice in your TB is about 70 degrees. I'm not sure cutting off the TB heater is going to make any difference in intake temps considering how small the surface area is, and your intake manifold likely gets way hotter anyway.
                        • p0cket penguins
                          • Jul 2008
                          • 481
                          so it wouldn't matter either way... cause your throttle body will be warmed up in a few minutes when your engine starts right?
                            • 34827
                            sure, but the velocity of the air is what cools down the throttle area and causes ice to form, it doesn't matter so much what the intake manifold temp is. If you think about it the two should cancel each other out leaving the throttle body at a normal temp. So by keeping the TB heater you are avoiding the issue of ice formation without sacrificing anything else.
                            • p0cket penguins
                              • Jul 2008
                              • 481
                              why doesnt the m30 and m50 engines have them?
