DME Fusible link replacement/ car backfire
  • 36brua
    • 689
    Link is dead. Source for replacement ? dealer item?Pelican/ Bav didn't list. Or alternate fuse possible? Cant find any specs anywhere
    '89 I stk mark d chip. car will not take throttle did all chks in Bentley cleaned connectors , vac leaks,fuel ohm etc. stumbles miss backfire on acceleration
    I searched and read a bunch but still can't locate prob
    any help is appreciated.
    Thanks
    My CA legal M60 swap
    The happening in our garage
    If the fusible link is dead, the engine won't run as that link supplies power to the DME.
    With those symptoms I'd suspect a fuel delivery issue, intake leak, bad AFM, or bad DME. The fuel system pressure and delivery tests are in the Bentley manual and a smoke test is the definitive test for intake leaks. Once those are eliminated as suspects try swapping in a known good AFM and/or DME.
    • 36brua
      • 689
      Hi ya- Thanks for the reply. to test I jumpered around the dead link so DME has power
      I did the fuel test yesterday everything seemed to be spot on. pres. /delivery. also swapped pressure reg. no change. tried another AFM that I believe is good.general Bentley potentiometer/ temp sensor were within range
      also seems to poss. be temp related.the coolant temp ohms were in range. it is intermittent ,more pronounced when the engine is hotter- mid day.
      I can have the smoke test done. so it's of f tho the 'professionals' tomorrow
      Did stomp test came up AFM , throt. positioner -within range.
      Any source for replacement Fusible Link ?!
      Thanks j levie..
        I'd just replace the fusible link with a 30A fuse.
        There are two coolnt temp sensors. One for the DME and one for the gauge. Which did you test?
        • 36brua
          • 689
          Hi thanx for the fuse info only amp ratings I could find related to 525 , I cant remember looked at so much stuff, any way. I was planning on doing a regular inline fuse.
          I check the blue sensor i think Bentl said a 68 deg +- the ohm reading was ok.
          also serching other sites came across post by thejlevie. you posted up spec 30 write up now I can't find it can you direct me? also found fault codes for 'stomp test from e30.......rld. I'm going to try those.
          only codes I had previously were from Bently.. G2G now
          Thanks
            I'm not sure what post you are referring to. My user name is thejlevie on Bimmerforums and everywhere else it is jlevie. So I'm unsure as to what you are referring to.
            • 36brua
              • 689
              Thanks for all the input!
              We replaced the fusible link in trunk and drove today in hot conditions no problems. have good voltage at bat. terminal in engine compartment.
