Tbelt questions....
    Tbelt questions....
    Ok so I did my tbelt and water pump, head gasket and the 1.3 swap last weekend and I got everything back together today and started. It runs nicely but there is there a weird noise from the front of the engine. It like an RPM related squeak, kinda like a belt squeal but its not one of the front belts. Im going to take the front end apart tomorrow to make sure the tbelt's not rubbing on anything. Has anyone had anything like this?
    Also, when i mash the throttle it seems to choke a little bit. I think my xfer pump is bad, could that be causing this?
    Brian
    BTW: This is for an 87 325 with Motronic 1.3
    alternator belt on too tight? did you adjust valves?
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
      All the belts have a little play in them like they should. Im going to adjust the valves today, but I don't understand why that would cause a noise like that.
      Brian
        Brian
        no noise, my valve comment was regarding your stumbling issue.. as for the noise, can you isolate to inside the timing belt cover?
        '91 SpecE30 #523
        128290
          Its coming from right around the cover. Ill get a steth out and check it when I get off work. Im going to pull the cover off and check it anyway just to make sure nothing is rubbing.
          As for the stumble that could make some sense. I'll see what happens when I adjust the valves today.
          Brian
            Did you replace the tbelt tensioner? They can squeak when old. Sometimes its more of a chirp than a squeak though.
            1987 E30 325is
            1999 E46 323i
            RIP 1994 E32 740iL
            oo=[][]=oo
              I hope so.. it's not pretty when a tensioner is re-used and it fails.
                of course I replaced the tensioner. Im not a damn noob, just curious about the squeak
                  OK, then don't be a noob and list it in what was replaced. See if I bother to help you again. Jeesh.
                  I won't bother to mention that if you didn't get the belt centered up, it will rub on the top cover, but I suppose that's a noob thing too right?
                  A real noob thing is being asked if you tensioned the fan belts correctly.... whoops, somebody else already did that...
                  1987 E30 325is
                  1999 E46 323i
                  RIP 1994 E32 740iL
                  oo=[][]=oo
                    chill dude, he was just throwing out some possibilities
                    1989 cirrisblau-metallic 325i
                      LOL What a fucking douche bag!! OMG someone said something off color to me, now Im so angry...Cry me a fucking river!
                      Anyone worth a shit care to chime in?
                      Brian
                        lol
                        Classic BMW Specialists
                        Santa Clarita, CA
                        www.BimmerHeads.com
                          Originally posted by MR 325 View Post
                          lol
                          you too, huh?
                            Recently did a timing belt, tensioner, water pump, and accessory belt changeout on a 90 vert.
                            The water pump made a fair amount of racket as I was adding coolant and bleeding the air out, but things are quiet now.
                            On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
                              Good Idea but it's got coolant and it didn't help either. I didn't get to pull things back apart yesterday but I should have my answer by today.
                              Brian
