charcoal cannister/bypass valve troubleshoot
  • strad
    • Jan 2007
    • 241
    Okay, problem is that on a really hot day (and only then) I get strong smell of fuel in the vicinity of the charcoal canister. Things I know so far:
    1: bypass valve connector shows battery voltage with ignition on (per Bentley)
    2: bypass valve makes a "click" (per Bentley) with ignition on.
    3: There are no apparent fuel leaks anywhere else in the engine compartment. Everything's really clean, so if there was a leak I think I'd see it.
    What I need to know is, is there anything else not stated in Bentley that would help me test the bypass valve, and, if any of you have had this problem before, what was/were the fixes you employed. I'm interested in doing this one by the book, so that if I move back to CA (like that'll ever happen lol) I won't get hell trying to smog the thing. Plus I don't like the smell of fuel when it's not supposed to be there.
    The current fleet:
    1992 325ic: 148k-171k miles
    1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
    1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
  • 36brua
    • 689
    check that the rubber hose on top of the bypass valve is still connected under the throttle body ?
    My CA legal M60 swap
    The happening in our garage
    • strad
      • Jan 2007
      • 241
      Yes, it is. I'm pretty sure this is not a connection problem. Every hose and hose clamp under the hood is new, except for the one connecting the canister to the firewall. I was just wondering if, on a hot day, my charcoal canister is getting more vapor than it can handle and somehow venting it. Do these things get tired after 17 years?
      The current fleet:
        • 34844
        charcol canister is probably done. I know mine is pretty nasty, I don't even like touching the thing.
