Compression
  • tehwickerman
    • Dec 2008
    • 1088
    Compression
    I decided to do a compression test on my M20... got around 155~157 on all cylinders. Bently said it should be 140. Anyone know if my compression is high or if Bently is just wrong?
    Those are reasonable numbers. Have you done a leak down test? It will tell a lot about the condition of the cylinders and rings.
      • 34847
      it's going to vary engine to engine, depending on how much carbon deposits there are, how the rings and valves are sealing, what the weather is like, how long you crank it, etc. etc.
      the important part is they are all close to each other. sounds like you are good to me.
      • tehwickerman
        • Dec 2008
        • 1088
        Good stuff, thanks for the input.
        • Knockenwelle
          • Jul 2008
          • 395
          Bentley numbers are a service minimum. Lower than 140 indicates problems.
          Mike
          '91 325i track car. Mostly...
          • strad
            • Jan 2007
            • 241
            Last time I looked, I remember bentley giving a range between 142 and 156 for all engines covered by the E30 manual. Dunno where you got 140. Also, you must account for altitude when you do a compression test (see "time to rebuild" in pelican's technical articles.)
            The current fleet:
            1992 325ic: 148k-171k miles
            1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
            1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
