So say I wanted a cam for my m20
  • Danny
    • 14216
    Schrick 288 or 284?
    DD some track duty, running on megasquirt.
    What would you say?
  • Aptyp
    • 6584
    284 idles better and low end torque stays the same. Had really hard time getting idle right with 280 and 288.
    I still have 280 laying around garage, Schrick hasn't made that one in almost 20 years for a good reason.
    • Danny
      • 14216
      I think I might go for a 284. Although I love the sound of James' 288.
      • der affe
        Technical
        • Dec 2005
        • 8452
        292 and get ITB's and at least 28lb/hr injectors
        be like me. the smog popo will really love you then
        • Danny
          • 14216
          Lulzzzzzzzzz
          Its gotta LOOK stock.
          • der affe
            Technical
            • Dec 2005
            • 8452
            pretend it is a benz or audi and make an engine cover;)
            they will never know.
            or tell them it is an S-14 or an S-52. they both have ITB's
            • James Crivellone
              Head Janitor
              • 6305
              Don't run anything over a 284 with stock pistons without an adjustable cam gear, the clearence is way too tight and you will have valve/piston contact depending on how much you have milled the head.
              On a perfectly stock motor that has never had the head pulled MAYBE, but I would not risk it. I've seen 3 blown up M20's running a 284/272 with a stock bottom end (including mine)
              • Danny
                • 14216
                Damn. M50 is looking better and better.
                • Dyno4mance
                  • 345
                  Nooo Schrick 288 all the way....revs like a sport bike:giggle::nice::mrgreen:
                  2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
                  • Knockenwelle
                    • Jul 2008
                    • 395
                    288 FTW. Sure, you lose a little torque below 2500, but if you're considering a cam, you're gonna drive it like you mean it. My 2.5 with a 288 revs happily to 7400, though I usually shift around 6900. An adjustable cam gear is definitely a requirement, as is VERY careful checking of P to V clearance.
                    And the sound!!! Gives me chills every time I wind it up.
                    Technical note: the 288 is a single pattern, with 288 degrees of advertised duration on both lobes, and a 110-deg LSA. The 284 is a dual-pattern, and has 284 deg intake duration, but only 272 deg on the exhaust, with a 110 deg LSA. Though the numbers may suggest otherwise, there is a BIG difference in cam "size" with the 288's longer exhaust duration. Not surprisingly, the 288 has a lot more overlap, and you will notice/hear/have to deal with it at idle. I've had some sorta-car-guy types ask me if I had a small-block in my car. Duuhhhh.....
                    Mike
                    '91 325i track car. Mostly...
                      • 34844
                      you aren't going to want a 288 with the 8.8:1 cr of a stock M20.
                      stick with the 284/272. it will idle fine, make plenty of power in the upper RPM range, and you can get away with using it with motronic and a chip. the 288 is quite a bit more aggressive and you're really just wasting most of it's potential on a stock motor.
