Charcoal Canister
  • bcrdukes
    • 107
    Charcoal Canister
    Have any of you had to replace your charcoal canister? If so, why and what were the symptoms experienced?
    1989 E30 BMW 325i
    1998 E36 BMW M3
    2004 E46 BMW 325i
  • 5KWattson
    • Apr 2009
    • 809
    the only reason that i can think of replacing it would be from a failed emissions test other wise just leave it alone they dont do much except hold excessive vapors from your gas tank for quicker warm up's but they really dont do anything for drive ability
    "God created turbo lag to give V8's a chance" Taylor D.
    • bcrdukes
      • 107
      If it were clogged, would it cause hard starts?
      1989 E30 BMW 325i
      1998 E36 BMW M3
      2004 E46 BMW 325i
      • reelizmpro
        • 9559
        Did you try another purge valve first?
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • bcrdukes
          • 107
          They're pretty hard to come by. And they're $200+ from the stealership. :(
          1989 E30 BMW 325i
          1998 E36 BMW M3
          2004 E46 BMW 325i
          • reelizmpro
            • 9559
            Really? I'm sure you guys have some local junkyards or someone here on the board has a used one they could sell you cheap. I had a few of them at one point.
            88 M3 - LACHSSILBER
            • bcrdukes
              • 107
              I'm going to swap one out of a known working 90 325i this weekend and see how it goes.
              1989 E30 BMW 325i
              1998 E36 BMW M3
              2004 E46 BMW 325i
              • RobE30
                • 959
                Check your manual for a quick diagnostic test to check the function of your existing check valve. I'm pretty sure the test is just disconnecting the valve from the canister and while still connected to the electrical plug, turn the key to the "on" position (but don't start it) and listen for a click. When I did the test on my 87 is, the valve didn't click @ first so I sprayed brake clean into the valve and shook it a little. Tried the test again and it worked fine. The only things I replaced were the rubber hoses going from the canister to the valve and the valve to TB (I think). Good luck and all that crap. The car did run a little smoother after changing the hoses so it's worth doing.
                09 BMW 328xi touring 6spd
                05 Subaru Outback XT 5spd
                87 BMW 325is
                a few bicycles
                • bcrdukes
                  • 107
                  I checked the valve. It clicks as per Bentley/Haynes manual. Took the CC out - no leaks/nothing. I think my injector(s) is/are leaking. :(
                  1989 E30 BMW 325i
                  1998 E36 BMW M3
                  2004 E46 BMW 325i
                  • g323
                    • Dec 2008
                    • 6
                    Mine had a vacuum leak in it
                    E21 1982 323i
                    Under the Hood:
                    M20B23 with 731 Head, Dogleg tranny
