Engine rattle in the morning. Like rod knock
  • Chuckcruzin1986
    • Jul 2009
    • 130
    Hi,
    1986 325es 220,000 miles
    I have a rattle in the morning and it sounds like a rod knock.
    I used a factory bmw oil filter.
    20 w 50w oil
    40 lbs pressure idle with engine at 80 degrees (start up in morning).
    60 lbs pressure at 2000 rpm
    I heard the check valve in the oil pump might be stuck so we pulled the pan and pump. Cleaned and inspected it........nice. Put it together and this morning I had a slight rattle, like two slaps.
    What could this be???
    Thanks, Chuck
    • 34839
    timing belt tensioner? trying to think of things that might rattle in an M20..
    • James Crivellone
      Head Janitor
      • 6305
      My M20 ETA back in the day did that around 210k miles.
      Cold oil was the major issue, the rod bearings looked fine, although one was a little tired. I got a stethoscope and determined it was simply rod knock at startup.
      • Liam
        • 753
        Piston Slap is common on high mileage m20's... Goes away warm right?
        Also the wrong (or cheaply made) oil filter can drain back... This could fit your symptom better. I recommend Mahle (OC49 is the correct number for all M20s)
        Last edited by Liam; 07-16-2009, 04:40 PM. Reason: My syntax sucks by the end of the day
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
